is a b16 motor good to boost on stock internals? really want to boost it but if its going to make my motor go bad quicker then i keep it N/A, but i heard b16 motors are good to boost , as long you get a good tune and run under 9psi , i know a Ls block is good for boost but really dont feel like going threw that process . So is it possible to make my b16 can handle boost without going bad on me? dont care about the hp i make , as long i make it sneeze lol , and the motor doesnt go bad . .
Did a compression check, compression # are good , No Leaks!
