help wont start
  • #16
    Originally posted by redteg View Post
    it could still main relay, but to check the timing look by the crank pully on the timin belt cover there is a mark line up the thick line on the pully
    deff not the main relay..but ill try and re-do the timing...
    WILSON BUILT
    • #17
      What color is your spark? You could possibly have a weak spark, go with the old sayin: Red is dead, blue is NEW. Basically if you have like a red/light orange spark, then it wont fire the mixture when the density is increased(compression). Or you could have your timing off. Where you located? Whats your number?
      • #18
        Originally posted by h23vteclude View Post
        what color is your spark? You could possibly have a weak spark, go with the old sayin: Red is dead, blue is new. Basically if you have like a red/light orange spark, then it wont fire the mixture when the density is increased(compression). Or you could have your timing off. Where you located? Whats your number?
        meriden 2035376525 blue spark
        WILSON BUILT
