help wont start
  • help wont start
    ok here is the deal..this isnt my first swap..but i am having a no start problem.
    i have a d15b vtec-e(for my daily) witch is a 93 civic ex
    i have fuel spark and power
    i feel like its a timing issues i need help asap will pay for some1 to come down 2day(saterday) hint hint kyle
    WILSON BUILT
    its def a good motor? and if so ur right the timings probly off if theres fuel spark and power
      yea i just got it from tigerjapanese..i ordered motors from them b4..worked out grate...i just dont have a timing gun an im not that good with timing issues so ill pay some1 to do it.
      WILSON BUILT
        i know gaz would hook it up but u probly dont wanna get it towed to hight output
          yea if it comes down to that ill have to get the trailer out n go..but ill c
          WILSON BUILT
            if its timing i dont' think u need the timing gun to get it to run .. check the belt .. its pretty easy on a single cam but i'll pay to get my ls done lol
              Originally posted by doitpropa View Post
              if its timing i dont' think u need the timing gun to get it to run .. Check the belt .. Its pretty easy on a single cam but i'll pay to get my ls done lol
              the t-belt is mint...brand new an tight not to tight but just right idk
              WILSON BUILT
                all your marks are on? take out the spark plugs and make sure the motor spins freely with no binding and do a compression check
                  i had that problem. with my 91 hatch. it turned out to be the main relay. it would get hot and not start. but i would deff. give that a shot.
                    but he has spark and fuel so thats not it
                      Originally posted by pizzaboy720 View Post
                      all your marks are on? Take out the spark plugs and make sure the motor spins freely with no binding and do a compression check
                      i had that problem. With my 91 hatch. It turned out to be the main relay. It would get hot and not start. But i would deff. Give that a shot.
                      yea it dose spin freely an smooth..ill do a compression check when i get outta work..
                      Not the relay..thanks tho
                      WILSON BUILT
                        bump someone help him get this single cam ready for hubbard park meet
                          its still ugly..lol but yea i hate driving my truck
                          WILSON BUILT
                            it could still main relay, but to check the timing look by the crank pully on the timin belt cover there is a mark line up the thick line on the pully
                            :cool:
                              just sure you take the spark plug out and set the piston top dead center and the car in neutral
                              :cool:
