Any Modification to a 96-98 ex engine harness
  • Any Modification to a 96-98 ex engine harness
    Okay , so my car needed a new engine harness , and i came across one from a friend , and its uncut ... i went on google and did some research and i seen some thread talking about the iavc need to be wire from a 3wire to a 2 wire . .is thats a true fact? , and what other mods gotta be done to this harness. .& oh Yea what about the CFK sensor . The motor is a b16a2 and in a 98 civic . .
    I'm hearing a ex 96 98 engine harness is a straight plug n play , and I have a 96 ex engine harness , but when I plug it up , the cfk plug doesn't reach to the input , like my old cut up engine harness , and there's a 3 plug that doesn't plug up 2 nowwhere ... I try cranking over my car and it starts but then stalls out . . Need some answers asap
    98Ex DD EJ8 ROADRUNNER
    can i get some answers?
      Damnn, like a thousand ppl on here , nd not even a bump or a answer??? I knoe couple of you been threw these process , lol . . . In need of help asap
        99 ek 4 dr sold
        97 ek coupe sold
        97 Nissan maxima se
          ^^^ thanks . . .
            bump solve this shit
              ^^ deff bro , and this thread gonna help a lot others that's on the same shyt lol . . Keep it up , hopefully somebody can solve the problem . .
                Do the ckf trick and if ur car dies out after turning it on check yur iacv...try giving it a lil gas check that ur gas cable is adjusted right
                ....to my knowledge u can run the car without ckf i believe teggys have 2 wire ckf and civic has 3 match the colors
                Follow me @bolacan413
                Follow the build @k_insight
                  ^^^ yea I was reading about the cfk trick . . And yea on my old harness , it has the 2 plug(it been modified for this swap) but it was a hacked up job , so hadda get a new one , nd that's what a couple ppl said , its fine to drive without it plug then , it only gonna throw a cel , and I'm guessing its the iacv too bcus some thread where saying I needa be wire to a two plug not a 3 plug ..so I prollly plug the wrong plug in the iacv ...
                    does the b16 have crank sensor?
                    if not did u by pass the crank sensor on the harness?
                    Down Since 09 ...
                    Mugen Inspired DC5
                      Da crank sensor sits under da alt? Nd I have a new harness , my old harness had evathing plug up , no cel , juss it was poppin ecu fuses due to a short somewhere in da harness..
                        Yea b16 does has a crank sensor , which I believe is call , cfk.. Nd da previos owner did the wiring on the old harness.. Reason for taking that harness out cus it had a short somewhere nd couldnt find it ..
                          bump for you bro i say check your iacv.. if you need to rewire it, do so. and see what happens
                            Thanks manny , deff bro .. Im guessin its da iavc plug ... Im see wat greg says bout it , maybe he wann do da wiring..
