Thanks bro ...
Any Modification to a 96-98 ex engine harness
What iacv do u have on the motor 3 wire or 2? And u gotta make it a 2 wire or vise versa? And the crank should be coming from behind the main pulley but the plug for it is by the alternator it should be a 3 wire. U got a obd1 b16 or obd2? And wheres the plug that's no plugged in what colors are they
good luck with wiring it up,thats why if i do a swap ima taking my sweet as time and getting every diagram known to gods green earth about the car/motor swap..and i would splice that wire loom and redo it to my liking.9-3-12 Legendary IG thatsmrmycocksafloppintoyou
Originally posted by Santi View PostWhat iacv do u have on the motor 3 wire or 2? And u gotta make it a 2 wire or vise versa? And the crank should be coming from behind the main pulley but the plug for it is by the alternator it should be a 3 wire. U got a obd1 b16 or obd2? And wheres the plug that's no plugged in what colors are they98Ex DD EJ8 ROADRUNNER
Originally posted by B13 SE-R View Postgood luck with wiring it up,thats why if i do a swap ima taking my sweet as time and getting every diagram known to gods green earth about the car/motor swap..and i would splice that wire loom and redo it to my liking.
True , but i didnt do the swap , traded cars , and figuring it out the engine harness is bad , so the previous owner really didnt do a good job from keeping wires from touching , so now, im taking my time wit this , trying make sure everything is wrapped up and wire fine . . .98Ex DD EJ8 ROADRUNNER
Im comparing my old harness to my new one , on my old harness they did the wiring right , they converted the 3 wire iavc plug to a 2 plug and extened the vtec wires , and convert the 3 wire CFK plug to a 2 wire ... the old harness didnt throw no CEL , only on the primary 02 sensor cus i didnt get a new yet . .98Ex DD EJ8 ROADRUNNER
