Engine problems.
  • #16
    iight i'll try that..
    • #17
      Nah the plugs aren't backwards. I switched up and its worse so I switched them back. Same problem.
      • #18
        Did u replace the throtel body ??if u did check the gasket this happend to me and I change like 4 map sensors change ecu like 3 times and it was the it had silicone on a lil hole the it got so the air can pass to the map sen cause someone put a gasket plus they put silicone on it too
        • #19
          Nah I didn't replace it.
          • #20
            Originally posted by Rey View Post
            @ crzycivic93 how much for the map sensor and wats ur location text me 860 818 4552
            i got one for 5 bucks
            !!!!!ThE GoOd DiE YoUnG!!!!!
            • #21
              what year is your car on some models the map sensor wiring is on firewall instead of engine harness
              • #22
                Got a 95 del sol with a b18b1 swap
                • #23
                  Should be on harness then have you checked the ecu to see if you burnt the board when you swapped plugs
                  • #24
                    No but when I Switched it back it still ran the same.
