Engine problems.
  • Engine problems.
    My swapped b18 doesn't idle right and it got a check engine due to a Map sensor, I changed the sensor and I still have the same problem and the engine light is still on..please people help me out.!! I need to go to emissions and I know I can't with a engine light on.
    I got a new map and gasket. LMK
      Dude I replaced it already with a brand new one and it's still doing the same thing.
        Originally posted by LS/Vtec
          clean the iacv
            make sure you don't have your tps n map plugged in backwards. If they arent your next thing to do is get a volt meter out and check the voltage on the wires to the map.
              X2^^^
                X3
                  I dont have a voltage tester and I looked that up already it seems confusing.
                    Map Sensor wires
                    YEL/RED
                    RED/GRN
                    GRN/WHITE
                    TPS Sensor wires
                    YEL/BLU
                    RED/BLK
                    GRN/BLK
                      Wouldn't there be a code for the tps? It's Basically rough idling like it seems like the car is gonna shut off but it doesn't it just keeps roughing it.
                        Lmfao
                            @ crzycivic93 how much for the map sensor and wats ur location text me 860 818 4552
                              your map,and tps plugs are backwards,switch the plugs up,,,,,,
