noob needs help
  • #31
    y a p28?
    • #32
      Why not if your gonna go vtec that would be the easiest ecu to find
      860 member #18
      puerto roc #1
      Cosa nostra
      ASAPRadio.net
      • #33
        whats that ecu out of? and its obd1?
        • #34
          the ecu comes in any 92-95 si or ex and yes it is obd1
          • #35
            ok next ? i wanna no if i need a new tranny shift linkage bushings or pin i can put it in 1st and wiggle the shifter from right to left with it in gear how do i tighten it soo it stops that?
            • #36
              change the pin and did you even check whts there now? put in a shifter eurathane bushing kit that is most likely your problem they are fairly cheap 20 bux or so..
              860 member #18
              puerto roc #1
              Cosa nostra
              ASAPRadio.net
              • #37
                ok was trying to figur out if it was my tranny or maybe the shiftlinkage where the pin goes was worn but ok kus im gettin a b&m shorty from work
                • #38
                  Ok so just work on things one at a time and eliminate all the small issues and then get the car going i thought you would a have started doing the conversion by now..
                  860 member #18
                  puerto roc #1
                  Cosa nostra
                  ASAPRadio.net
                  • #39
                    well i need a new intake befor i can do the mpfi convert then i need the jumper harness and ecu then need a motor
                    • #40
                      And if where the pin goes its warn out then you will continue to have the same issue that means that joint is no good i would rectify that before getting short shifter.
                      860 member #18
                      puerto roc #1
                      Cosa nostra
                      ASAPRadio.net
                      • #41
                        Intakes are everwhere use a z6 intake then get a p28 i even can sell you one if needed and the harness is like 70 bux at most.
                        860 member #18
                        puerto roc #1
                        Cosa nostra
                        ASAPRadio.net
                        • #42
                          kk soo pin and bushings first then if needed linkage ?
                          • #43
                            exactly look you can get almost all these parts including a linkage if needed for about 350 if that you need to apply yourself and then get it if you need help locating the parts lmk i will help u. alot of the waterbury dudes know me and i've been a mod here for a long time and am always willing to help out the members so just lmk bro i'm in htfd ..
                            860 member #18
                            puerto roc #1
                            Cosa nostra
                            ASAPRadio.net
                            • #44
                              thanks boss its just ben hard meetin people here that are into cars and that dont hate other honda drivers but yea trying to get this dude to return my call about a d15 vtec for $200? does that sound ok for up here in sc i could get that for like 100$
                              • #45
                                Yeah i know down there it's deff alot cheaper then here but you have moved to a spot that everyone owns one and the community is large in the hone scene. i actually know someone who has one a z6 he texted me and told me it's for sale and the engine is deff good. i will check and see wut he says and let you know..
                                860 member #18
                                puerto roc #1
                                Cosa nostra
                                ASAPRadio.net
