FS: B Series Turbo Kit
  • FS: B Series Turbo Kit
    Inline Pro Manifold B Series
    Tial 38mm Wastegate
    7 Psi and 12 Psi Tial Wastegate Springs
    Garret Turbo M11 Exhaust A/R - .48 Intake A/R - .60
    Stainless Steel 2 1/2 Inch Downpipe With Built In Flex Pipe
    Intercooler Piping/Couplers/Clamps
    Precision Intercooler
    Greddy RS Blow Off Valve
    DSM 450cc Injectors With Resistor Box
    Oil Feed Line
    Oil Return Line
    Golden Eagle Sandwich Plate For Feed
    Half Mount Radiator
    Autometer Boost Gauge
    Autometer Oil Pressure Gauge
    Aem Wideband O2 Sensor/Gauge
    Price
    $1050 With everything listed
    $950 No Wideband
    $850 No Wideband and Injectors
    Needs. 1 Oil feed line fitting, and 1 coupler from turbo to i/c piping. I'll buy the fitting if I go to AutoZone tomorrow.
    I'm gonna look for the coupler tomorrow.
    Don't like the price? Go buy Ryans ebay kit for $800. Because I DON'T CARE.
    Bump for my good friend Jordan...good luck with your sale friend
    Originally posted by LS/Vtec
      Thanks Eric.
        hey do u no if i can put 1 b16 cam in my single cam and if so which is the better one ex or intake?thx
          ^intake cam because it has the slot in the end for the dizzy.
            ^Lmfao x2 how u gunna run it also bro I got it goin no check engine lol hmc when ever
              well my boi said dat i could die grind the ex cam and make dat slot so idk i guess intake has longer piston stroke combo ne way
                I'm new to boost an this seem like a good kit will a stock ls hold this on like 8-9 pounds?
                  ^^I wouldn't run nemore than 6 or 7lbs on a STOCK LS
                    Bump for boost...
                      Personally I'd just run the wastegate with no spring and just see what happens..
                        ant trades
                          Lmfao I have no clue when it comes to boost but it sounds like a disaster with no spring
                              I had this on a stock LS with 7psi and it scooted! Mark is running 14psi on his stock ls with a bigger turbo.
                              It would be. It would boost until the motor popped lol
