Smoking problem
  • Smoking problem
    Ok theres a h23 vtec engine thats runnin on a .50 trim t3/t4 emusa turbo but its smoking so tha turbo was replaced n it still smokes. Does ne 1 have an idea of where tha smoking comes from? It smokes straight out tha back i think its coming from tha block but no sure. Need ideas!!!! Need helppp!!!
    Compression test to start and if its good probably bad valve seals
      If its in boost its piston rings
        Thanks guys bump
          99% chance it is rings on a Hseries with boost
            Ne 1 kno where i culd get this stuff checked out and installed???
                Def sounds like blow by, usually piston rings but check compression to verify
                  Where can i get that compression test?
                    autozone
                      Autozone? Really? Lol
                        yes they sell and rent them
                          Ive never heard of that idk if i believe u
