Window problem
  • Window problem
    Ok my driver window won't go down I was about to smash it out since I have s extra glass but its not worth it I have a new motor window switch everything it's not the fuse an the power lock in the door handle doesn't lock the passenger side u can care less about that I just want my window to work an way to hard wire it? Plz lmk ASAP
    Always on that fire
    Check for thison the door plug.
    R.I.P NHSWAPS13203
      ^^ common issues with high mileage car
        The wires get brittle and break and what not very very common on ek civic 4dr I have seen quite a few
          Thanks guys ill check it out
          Always on that fire
            not just the door plug but all the wires from the plug to the motor. i had a wire break half way threw the door.
