itr dc2 cluster in 91 ef issues.
  • itr dc2 cluster in 91 ef issues.
    if any one has done one can i have answers to why i cant get it to read on any of the needles. fuel, temp , and tach. idk about the speedo but that probable does not work either even thou i wired up the vss to ecu and cluster.
    what does work is, back light, blinkers, hazard. and when i put power to oil,check engine, door, and ebrake thous work. but i cant get the needles to read, and i have been blowing fuses trying to fig it out .
    this is what im going bye.
    Honda CRX / EF Civic (1988 - 1991) - GSR cluster Pinouts and 90-91 Crx Pinouts a HOW-To and I need help!! - Here are the 94-99 Integra and 90-91 Crx guage cluster pinouts and how I put them together. Ok so after spending some days on this little project and searching the web for some pinouts I just opened a Service...
    im guessing i am getting power to the temp and fuel gauge becuase they move very little either down or up when i turn key..
    If your blowing fuses then you have a wire mixed up. How exactly did you wire it,pics help?
    R.I.P NHSWAPS13203
      ill post some up later. what i did was wire the correct color wire from the car to the same color wire on the cluster pig tails. and after i did that and got horrible results with not much working or lighting up, i started experimenting and thats why i blew some fuses.
        Are you 100% sure the cluster works?
        R.I.P NHSWAPS13203
          how do i test it to see if its works? when i bought it off ebay said it was tested and works. have you done this swap be for? willing to pay to have some one come and get it working..
              cut the grey wire should work
