**Eg Help***Plz Help***
  • **Eg Help***Plz Help***
    Fixed close thead
    Follow Me On Instagram
    Jdmkid618
    fuse? does your license plate light work?
      Nah
      Jdmkid618
        Bump gl
        J.R. Built not Bought
          i've seen this scenario once. It has something to do with the wiring behind the license plate light
            check fuse or change the bulbs if they are dual filliment ones i had the problem with my integra try those g/l hopefully it works
              Im gonna double check the fuses again n check that plate light wires
              Jdmkid618
                double check the grounds inside the engine bay i had a similiar problem before
                  Grounds in the bay should be fine
                  Jdmkid618
                    fuse went bad or the switch on for the parking lights been there befro
                      My headlights turn on tho
                      Jdmkid618
                        good luck chuck
                          sounds like a ground problem. check in the rear somewhere for one
                          Ek hatch lsv daily...
                          860
                            Need this fixed
                            Jdmkid618
                              its the wiring behind the license plate. If your fuses are good, and grounds, its def that
