99 hatch leaking water pass. floor
  • 99 hatch leaking water pass. floor
    Hey guys yesterday I noticed water pooling on the front passenger floor of my 99 dx hatch. Been researching all day and ripping apart the interior of the car and cannot find the source of the leak. Just wondering if anyone else had this issue and what it was from. Any advice/suggestions are appreciated
    Rip the whole int out , have someone outside with the hose on the car as ur in there spotting where the waters running from ! Gl
      Well i poured a bucket of water over the car and didnt see any more water enter the car. Not sure of where its coming from, maybe the windshield isnt sealed tight? Seems like the front/firewall area is dryer than the rest of the area so guessing the a/c condensation issue is not the problem, but idk
        might be your heater core is leaking.check your coolant level.make sure its water and not coolant
        Originally posted by knuckk
          i know you got a ek but my eg hatch was leaking in the cowl where theres the open vent above where the blower motor is, and theres a seam and mine was leaking through there, i had to jbweld it and never leaked since.
          and mind you every time it rained my passenger front floor looked like a pond, 2 inches of water
            I had this problem before it was leaking at the top corner of the windsheild and leaking down the pillar onto the floor.
              hmm.. well its definitely not coolant, and not sure about those areas. gonna try to clean it up and look for an opening that could leak. thanks for the input guys
                I had the same problem and this was also the area it was leaking from. Why I did was pulled my a pillar covers off. And waited till it rained and parked it outside and watched where it was coming in from.
                  guess ill try that^. Just poured water over it and found a little trickle come from behind the ecu but cannot see where it came from.
                    well pulled the pillar cover off and poured a bucket of water over the car and didnt see any water leaking in anywhere.
                      So the water is coming in from behind/above the ecu. Still not sure where it is entering the car though. Getting pissed lol. anyone else have advice?
                        check what i said, inside the front cowl
                          Dont think thats it because its leaking on from where the ecu is located. Drips down right behind it
                            Alex you were right. Took that pillar cover off and sprayed the hose on it and sure enough saw the water leaking in. What did u do to seal it? just squirt some sealer underneath the weatherstripping in the top corner?
                              Gl bro this hasn't happend to me yet and I hope it doesn't.
