D16y8 need help like now
  • D16y8 need help like now
    203-887-4837 if you fuck with SOHC VTEC engines please call me I need help and have some questions I need answers ASAP.
    I did a full tune up new head gasket,water pump,T-belt etc. The car runs but there is a knocking sound, it's not very loud but noticeable and now I'm tryna find out what it could be. I drove the car to work and everything no lost in power or anything I just need to figure out what is off.
      motor is junk.. all the Y series motor spin berings at some point good chance yours did
        I found out what is was no spun bearing.
          Valve adjustment?
          ~D Block~
            N are you the guy I sold that valve cover to at mcd's on the pike a few months back?
            ~D Block~
              Yea that was me lol. I still have that valve cover in my garage. I fixed the issue my crank was off a tooth. I re-timed it and the car runs fine. It's always something, I knew it wasn't going to that easy.
                ^good to hear you got the situation fixed and under control.. Take care homie..
                ~D Block~
                  You to man
                    Your timing is most likely off. Check it with a timing gun. That's the only way for u to tell that it's 100% accurate. If your dizzy doesn't line up with the timing marks,then it's off a tooth or more. I can check/adjust your timing if needed. Pm me if anything
                    Originally posted by knuckk
                      Edit:didn't noticed that u figured out the issue. I knew it was most likely timing.
