Ignition help!
  • Ignition help!
    close
      bump help!
        Bump hope u figure this out.... someone help a fellow member I know someone has the info he needs.
          thanks man bump tryna save some money and do it myself
            Remove the white switch (the part where the thick wires are connected to) it has two screws holding it in place. Take a look at it and see if it looks stripped.It can also be the entire ignition switch its self.
            Originally posted by knuckk
              the whole switch is the part i have up there? the one for $150 or do i have to get another part too
                  ttt help!
                    The one for $97.99 is complete with everything. I usually go to the junkyard and check the same year(s) model Honda as what I own and sometimes the ignition switch has the key attached to it.so i would remove it or take the ignition off from a car at the junkyard and get a key made for around $40 from karpillow safe & lock in Bridgeport CT.I prefer oem parts. That's the reason why I'm telling you this but the autoZone one will still work for you
