jdm climate control
  • jdm climate control
    So I'm using my usdm harness on my del sol and noticed the Jdm climate control plugs are different .. any info on how to wire this or swapping faces etc would help...
    Another q? Does the usdm engine harness plug up to Jdm under dash harness?
    Again any info would help tryin to finish this car asap..
    Bumpzzzzz
      the jdm climate control didnt come with pig tails?
        Ya but I don't like cutting wires unless I REALLY have to.. I have the complete rhd harness but Idk if the engine harness is still plug and play..
          Bump .. Google hasn't helped for shit..
            Ur better of posting this on Honda tech. But I'm like you I don't like to snip away unless that's the last resort. if anything you can find the pinout for the jdm one or figure out the pinout on ur own using the jdm harness and depinning the usdm and repin the jdm plugs. Why aren't you using the jdm harness though?
              I'm on the same boat though kind of. I'm trying to figure out the pinout for an EL hazard button and no luck I'm going to have to sit down and play with wires =\
                Originally posted by Santi View Post
                Ur better of posting this on Honda tech. But I'm like you I don't like to snip away unless that's the last resort. if anything you can find the pinout for the jdm one or figure out the pinout on ur own using the jdm harness and depinning the usdm and depinning the jdm plugs. Why aren't you using the jdm harness though?
                I read that the usdm engine harness isn't plug and play with the rhd harness .. if I had a rhd engine harness i'd b set .. I was thinking of depining them but I havent really looked at the plugs to see if they even have the same amount of wires or anything but tomm ima figure it out one way or another...
                  Yea I think depinning them is ur best bet for a cleaner more oem look rather than cut and splice
