Dimming Problem
  • Dimming Problem
    my car started to do this today.. i'd press on the brake while the car is idling at a stop light during night time andd the rest of the lights dim out... then i press on the gas and go back to normal? wuts the problem in my ef?
    Its only A Single Cam
    I my EF
    93 Nissan Sentra 4Dr Xe- Gone
    91 Civic Hatchback- sold :(
    95 Nissan 200sx SE 2Dr- Sold
    08 Subaru Legacy Sedan- Love It banna
    Time to get a new battery.
      i'll agree wit herm on that one looks like you might have a charging problem
      860 member #18
      puerto roc #1
      Cosa nostra
      ASAPRadio.net
        really? a battery can cause that? i thought it be a grounding problem.. the car was just fine until last night.. but ill try that and see if its the problem
        I my EF
          Test your battery first and also check your connections it might be a bad ground but from what i hear i think it might be the battery.
          Crushing Egos.....
            it was the battery.. car runs much betta.. but still ima clean out all the grounds tommoro... thankx guys
            I my EF
              you should check out your alternator too it could of stopped charging your battery, while buying a new battery will only last so for long until that one is drained too
              R.I.P. Joseph K. Edwards
              12/30/1985-1/27/2007
                Glad to hear you solved the problem.
                Crushing Egos.....
                  nah that was the first thing i checked the alternator.. but i shouldnt have a problem becasue its new anyways... and problems already fixed... like i said i also cleaned up all my grounds and added a spare one
                  I my EF
                    yea man im glad tooo... :)
                    I my EF
                      i upgraded my grounds to 4gage it stops the dimming if u run hi power amps and i use a diffeerent battery one from a neon in my 91 hb si
                        this thread is old. he already fixed it.
