need help with passenger window and door lock
  • need help with passenger window and door lock
    so couple months ago the window stopped rolling down. iam guessing loss of power or window reg needs to be replaced. but the door lock worked when i would press the lock button on my key fab. now neither of them work but my driver side does. does anyone have any trouble shooting ideas so i can fix the problem. its summer and the woman wants the window down. haha and i want the door to lock when i press the key fab lock button thanks!
    bump need help ctvtec
      take it apart n see wat u got.. check fuse box as well homie.. cus there are fuses for the power windows n lock.. mite need to replace all tha motors if neting..
        i know theres a motor for the window but theres one for the locks to? and i will check my fuses but iam pretty sure they are good.
          If you have power locks then yes, there's an actuator for them. Check wiring connections and fuse contacts. Make sure there's no corrosion.
          Hidin' out
            i have my door panels off only the driver side door has the acuator. but what do i check on passenger door where problem is
              look for noticeable problems then start going in with a currency light
                never thought of that. i will try that. thanks, any other trouble shooting ideas
                  either the door switch isnt working the window motor is shot or its a fuse
                    i see this issue all the time. its the actual swith on the door panel. first problem is the window not working, then the locks. swap out the entire switch panel
                    RIP Nick Haines
                      i used a test light on all wires and connections. got everything works fine. checked fuses all good....is it the the passenger side window switch for the window but what about the door lock??
                        The automatic locks don't work at all right?
                        Hidin' out
                          only the driver side works. u have to manualy lock the passenger side. and the window on passenger doesnt work. i tryed to use my boys switchs and it didnt do anything...wtf!
                            did your window ever start going dwn slow like it was getting stuck?
                              yea it did ten it just stopped and never did it again
