Torque Specs
  • Torque Specs
    ALL TOQUE SPECS ARE IN FT-LB.
    1 FT-LB = 12 IN-LB
    A/T Tranny Drain plug..............................29
    M/T Tranny Drain and fill plug....................30-40
    Wheel Lug Nuts......................................80
    Fuel Filter
    Banjo Bolt............................................16
    Service Bolt..........................................9
    Clamp Bolt............................................9
    Valve cover Bolts.....................................7
    Spark Plugs............................................1 3
    Cam Gear Bolt.........................................27
    Cam cover crown nuts..............................7
    Crank(vibration) damper bolt......................119
    Cylinder Head Studs.................................1st step..22...2nd..49
    Flywheel Bolts M/T...................................76
    Drive Plate bolts for A/T............................54
    Header Bolts to Cylinder Head.....................22
    Header to downpipe bolts..........................33
    Intake Manifold Bolts................................16
    Oil Pan bolts............................................9
    Oil pick up tube bolts................................17
    Oil Pump to engine block bolts/nuts.............9
    Oil Pump Screen bolts...............................8
    Oil pump cover Screws.............................5
    Oil filter Housing Bolts..............................9
    Rocker arm shaft pedestal bolts................16
    Rocker arm shaft end caps bolts................9
    Timing belt adjstment bolt.........................31
    Rod Bolts............................................. ....23
    Main Bearings cap bolts
    Separate caps and bridge..........................48
    One piece cap assembly............................33
    Water pump pulley bolts.............................9
    Thersmostat housing bolts..........................9
    Water pump attaching bolts.........................9
    Fuel injection service bolts
    88-90................................................ ......9
    91up.............................................. ..........11
    Throttle Body nuts.....................................16
    Fuel Rail nut..............................................9
    Manual Transmission
    Countershaft locknuts................................65
    End cover bolts.........................................9
    Selector arm holder bolts...........................9
    Tranny case to Flywhee housing..................20
    Tranny to engine bolts
    4 speed............................................. ........33
    5 speed............................................. ........50
    Clutch pressure plate bolts...........................19
    Release fork bolts........................................22
    Driveaxle/hub nuts.......................................134
    Brake hose to caliper banjo bolts (front/Rear)...25
    Master Cylinder Mounting nuts.......................11
    Brake Booster mounting nuts.........................9
    I didn't Make this list, Im just posting for reference to other members.
    what head and head studs are those torque specs for
      specification.
      good info though
        Bump for some nice info
        (203) Crew Member #15
        R.I.P Nick . We love you homie
          F that 100 ft lbs everything
          j/k
          MLF motorsports
            j/k
            impact gun...full power. fuck it. lol jk
              i usually just tighten everything till i shit my pants...
              BOOST
                tighten the bolts until they break then back off a quarter turn. lol
                  Originally posted by 4door89 View Post
                  i usually just tighten everything till i ************ my pants...
                  LOL. I like that one
                  Greatness is only 1,320 ft. away!!!
