more codes
This is a sticky topic.
  • more codes
    P1078 Intake Mainfold Runner Control (IMRC) System Malfunction (High rpm)
    P1106 Barometric Pressure (BARO) Sensor Circuit Range/Performance Problem
    P1107 Barometric Pressure (BARO) Sensor Circuit Low Voltage
    P1108 Barometric Pressure (BARO) Sensor Circuit High Voltage
    P1121 Throttle Position (TP) Sensor Lower Than Expected
    P1122 Throttle Position (TP) Sensor Higher Than Expected
    P1128 Manifold Absolute Pressure (MAP) Sensor Circuit Lower Than Expected
    P1129 Manifold Absolute Pressure (MAP) Sensor Circuit Higher Than Expected
    P1130 Demand for Changing Both Secondary Heated Oxygen Sensor (Secondary HO2S)
    (Sensor 2) and Third Heated Oxygen Sensor (Third HO2S) (Sensor 3)
    P1149 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
    P1149 Air/Fuel Ratio Sensor (Sensor 1) Circuit Lean Range
    P1157 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS Line High Voltage
    P1157 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Circuit High Voltage
    P1157 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
    P1158 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS- Terminal Low Voltage
    P1159 Air/Fuel Ratio (A/F) Sensor (Sensor 1) AFS+ Terminal Low Voltage
    P1162 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response
    P1163 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Slow Response
    P1163 Air/Fuel Ratio Sensor (Sensor 1) Slow Response
    P1164 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
    P1164 Air/Fuel Ratio (AF) Sensor (Sensor 1) Circuit Range/PerformanceP1165 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Range/Performance Problem
    P1165 Air/Fuel Ratio Sensor (Sensor 1) Circuit Range/Performance
    P1166 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Heater System Electrical Problem
    P1166 Heated Oxgen Sensor Sensor1 (Primary HO2S) Heater Circuit Malfunction
    P1167 Air/Fuel Ratio (A/F) Sensor (Sensor 1) Heater System Malfunction
    P1167 Heated Oxygen Sensor Sensor1 (Primary LAF HO2S) Heater System Malfunction
    P1168 Air/Fuel Ratio (A/F) Sensor (Sensor 1) LABEL Low Voltage
    P1169 Air/Fuel Ratio (A/F) Sensor (Sensor 1) LABEL High Voltage
    P1182 Fuel Temperature Sensor Circuit Low Voltage
    P1183 Fuel Temperature Sensor Circuit High Voltage
    P1253
    P1259
    VTEC System Malfunction
    P1297 Electric Load Detector (ELD) Circuit Low Voltage
    P1298 Electric Load Detector (ELD) Circuit High Voltage
    P1300 Random Misfire
    P1324 Knock Sensor Power Source Circuit Low Voltage
    P1336 Engine Speed (RPM) Fluctuation Sensor Intermittent Interruption
    P1337 Engine Speed (RPM) Fluctuation Sensor No Signal
    P1355 Front Ignition Coil Power Circuit Malfunction
    P1359 Crankshaft Position (CKP)/Top Dead Center (TDC) Sensor Circuit Malfunction
    P1361 Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) Intermittent Interruption
    P1361 Top Dead Center (TDC) Sensor Intermittent Interruption
    P1362 Camshaft Position (CMP) Sensor A (Top Dead Center (TDC) Sensor) No Signal
    P1362 Top Dead Center (TDC) Sensor No Signal
    P1366 Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) Intermittent Interruption
    P1366 Top Dead Center (TDC) Sensor 2 Intermittent Interruption
    P1367 Camshaft Position (CMP) Sensor B (Top Dead Center (TDC) Sensor) No Signal
    P1367 Top Dear Center (TDC) Sensor 2 No Signal
    P1381 Cylinder Position (CYP) Sensor Intermittent Interruption
    P1382 Cylinder Position (CYP) Sensor No Signal
    P1410 Air Pump Malfunction
    P1415 Air Pump Electric Current Sensor Circuit Low Voltage
    P1416 Air Pump Electric Current Sensor Circuit High Voltage
    P1420 Nox Adsorptive Catalyst System Efficiency Below Threshold
    P1438 Motor Drive Module (MDM) Overheating Signal Circuit
    P1439 Motor Drive Module (MDM) Short Circuit Sensor Problem
    P1440 IMA System Problem
    P1445 Bypass Control Problem
    P1448
    P1449
    Battery Module Overheating
    P1449 Battery Cell OverheatingP1449 Battery Module Individual Voltage Input Deviation
    P1449 Battery Module Deterioration
    P1449 Battery Module Deviation
    P1454 Fuel Tank Pressure (FTP) Sensor Range/Performance Problem
    P1456 Evaporative Emissions (EVAP) Control System Leakage (Fuel Tank System)
    P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System)
    P1459 Evaporative Emission (EVAP) Purge Flow Switch Malfunction
    P1491 Exhaust Gas Recirculation (EGR) Valve Insufficient Lift
    P1486 Cooling System Malfunction
    P1498 Exhaust Gas Recirculation (EGR) Valve Position Sensor Circuit High Voltage
    P1505 Positive Crankcase Ventilation (PCV) Air Leakage
    P1508
    P1519
    Idle Air Control Valve (IACV) Circuit Malfunction
    P1509 Idle Air Control Valve (IACV) Circuit Failure
    P1522 Brake Booster Pressure Sensor Circuit Low Voltage
    P1523 Brake Booster Pressure Sensor Circuit High Voltage
    P1524 Brake Booster Pressure Sensor Range/Performance Problem
    P1541 Climate Control Unit Signal Circuit Low Voltage
    P1542 Climate Control Unit Signal Circuit High Voltage
    P1565 Motor Commutation Signal Problem
    P1568 Battery Module Individual Voltage Input Problem
    P1568 Battery Module Temperature Signal Circuit Problem
    P1568 Battery Cell Temperature Signal Circuit Problem
    P1572 Motor Drive Module (MDM) Temperature Signal Circuit Low Input
    P1572 Motor Drive Module (MDM) Temperature Signal Circuit High Input
    P1576 Motor Drive Module (MDM) Voltge Signal Circuit Low Input
    P1577 High Voltage Detection Signal Circuit Problem
    P1580 Battery Current Circuit Problem
    P1581 Motor Power Inverter (MPI) Module Current Signal Circuit Low Input
    P1581 Motor Power Inverter (MPI) Module Current Signal Circuit High Input
    P1581 Motor Power Inverter (MPI) Module Current Signal Circuit Problem
    P1582 Motor Current U Phase Signal Circuit Low Input
    P1582 Motor Current U Phase Signal Circuit High Input
    P1583 Motor Current V Phase Signal Circuit Low Input
    P1583 Motor Current V Phase Signal Circuit High Input
    P1584 Motor Current W Phase Signal Circuit Low Input
    P1584 Motor Current W Phase Signal Circuit High Input
    P1585 Motor Current Signal Circuit Problem
    P1586 Motor Power Inverter (MPI) Module Current Signal/Battery Current Signal Circuit Problem
    P1607 Engine Control Module (ECM)/Powertrain Control Module (PCM) Internal Circuit Malfunction
    P1630 Transmission Control Module
    P1635 Battery Condition Monitor (BCM) Module Proble
    P1639 MOTB Signal Circuit MalfunctionP1640 ACTTRQ Motor Torque Signal Circuit Low Input
    P1641 ACTTRQ Motor Torque Signal Circuit High Input
    P1642 QBATT Battery Signal Circuit Low Input
    P1643 QBATT Battery Signal Circuit High Input
    P1644 MOTFSA Signal Malfunction
    P1645 MOTFSB Signal Malfunction
    P1646 MOTSTB Signal Malfunction
    P1647 Power Command Signal Circuit Low Input
    P1647 Power Command Signal Circuit High Input
    P1647 Engine Torque Signal Circuit Low Input
    P1647 Engine Torque Signal Circuit High Input
    P1647 Mode Signal Circuit 1 Low Input
    P1647 Mode Signal Circuit 1 High Input
    P1647 Mode Signal Circuit 2 Problem
    P1647 Engine Speed Signal Circuit Problem
    P1648 Battery Condition Monitor (BCM) Module Communication Signal Circuit Problem
    P1648 Motor Control Module (MCM) Communication Signal Circuit Problem
    P1655 CVT-FI TMA/TMB Signal Line Failure
    P1656 Problem in PCM-toVTM-4 Control Unit Communications Circuit
    P1660 A/T-FI Data Line Failure/TCM - ECM Halt
    P1676
    P1678
    FPTDR Signal Line Failure
    P1679 RSCD Signal Circuit Malfunction
    P1681 A/T FI Signal A Cicuit Low Voltage
    P1682 A/T FI Signal A Circuit High Voltage
    P1683 Throttle Valve Default Position Spring Performance Problem
    P1684 Throttle Valve Return Spring Performance Problem
    P1686 A/T FI Signal B Circuit Low Voltage
    P1687 A/T FI Signal B Circuit High Voltage
    P1705 Short in Transmission Range Switch Circuit (More than one range position is on at the
    same time)
    P1706 Open in Transmission Range Switch Circuit
    P1709 Problem Transmission Gear Selection Switch Circuit
    P1730 Problem in Shift Control System:
    Shift Solenoid Valve A and D Stuck OFF
    Shift Solenoid Valve B Stuck ON
    Shift Valves A, B, and D Stuck
    P1731 Problem in Shift Control System:
    Shift Solenoid Valve E Stuck ON
    Shift Valve E Stuck
    A/T Clutch Pressure Control Solenoid Valve A Stuck OFF
    P1732 Problem in Shift Control System:
    Shift Solenoid Valve B and C Stuck ON
    Shift Valves B and C StuckP1733 Problem in Shift Control System:
    Shift Solenoid Valve D Stuck ON
    Shift Valve D Stuck
    A/T Clutch Pressure Control Solenoid Valve C Stuck OFF
    P1734 Problem in Shift Control System:
    Shift Solenoid Valves B and C Stuck ON
    P1738 Problem in 2nd Clutch Pressure Switch Circuit
    P1739 Problem in 3rd Clutch Pressure Switch Circuit
    P1740 Problem in 4th Clutch Pressure Switch Circuit
    P1750 Mechanical Problem in Hydraulic Control System of A/T Clutch Pressure Control Solenoid
    Valve Assemblies A and B, or Problem in the Hydraulic Control System
    P1751 Mechanical Problem in Hydraulic Control System of Shift Solenoid Valve B and A/T Clutch
    Pressure Control Solenoid Valves A and B, or Problem in the Hydraulic Control System
    P1753 Problem in Torque Converter Clutch Solenoid Valve Circuit
    P1751
    P1768
    Problem in Torque Converter Clutch Solenoid Valve B Circuit
    P1773 Problem in A/T Clutch Pressure Control Solenoid Valve B Circuit
    P1790 Throttle Position (TP) Sensor Circuit Malfunction
    P1791 Vehicle Speed Sensor (VSS) Range/Performance Problem
    P1792 Problem in Engine Coolant Temperature (ECT) Sensor Circuit
    P1793 Manifold Absolute Pressure Sensor Circuit
    P1870 Problem in CVT Speed Change Control Valve Assembly Circuit
    P1873 Problem in CVT Pulley Pressure Control Valve Assembly Circuit
    P1879 Problem in CVT Start Clutch Pressure Control Valve Assembly Circuit
    P1882 Problem in Inhibitor Solenoid Circuit
    P1884 Secondary Gear Speed Sensor 2 Circuit Malfunction
    P0461 Fuel Gauge Sending Unit Range/Performance Problem
    P0462 Fuel Gauge Sending Unit Circuit Low VoltageP0463 Fuel Gauge Sending Unit Circuit High Voltage
    P0496 Evaporative Emission (EVAP) System High Purge Flow
    P0497 Evaporative Emission (EVAP) System Low Purge Flow
    P0498 Evaporative Emission (EVAP) Canister Vent Shut Valve Control Circuit Low Voltage
    P0499 Evaporative Emission (EVAP) Canister Vent Shut Valve Control Circuit High Voltage
    P0500 Vehicle Speed Sensor (VSS) Circuit Malfunction
    P0501 Vehicle Speed Sensor (VSS) Range/Peformance Problem
    P0505 Idle Control System Malfunction
    P0506 Idle Control System RPM Lower Than Expected
    P0507 Idle Control System RPM Higher Than Expected
    P0511 Idle Air Control (IAC) Valve Circuit Malfunction
    P0521 EOP Sensor Range/Performance Problem
    P0522 EOP Sensor Circuit Low Voltage
    P0523 EOP Sensor Circuit High Voltage
    P0560 ECM Back-up Circuit Low Voltage
    P0563 Engine Control Module (ECM)/Powertrain Control Module (PCM) Power Source Circuit
    Unexpected Voltage
    P0600 Multiplex Control System Troubleshooting
    P0603 ECM/PCM Internal Control Module Keep Alive Memory (KAM) Error
    P0606 ECM/PCM Processor Malfunction
    P0661 Intake Manifold Runner Control (IMRC) Valve Position Sensor Circuit Low Voltage
    P0662 Intake Manifold Runner Control (IMRC) Valve Position Sensor Circuit High Voltage
    P0685 ECM/PCM Power Relay Control Circuit Malfunction
    P0700 Automatic Transmission Control System
    P0705 Short in Transmission Range Switch Circuit (Multiple Shift-position Input)
    P0706 Open in Transmission Range Switch Circuit
    P0710
    P0711
    Problem in ATF Temperature Sensor Circuit
    P0712 Short in ATF Temperature Sensor Circuit
    P0713 Open in ATF Temperature Sensor Circuit
    P0715
    P0716
    Problem in Mainshaft Speed Sensor Circuit
    P0717 Problem in Mainshaft Speed Sensor Circuit (No Signal Input)
    P0718 Mainshaft Speed Sensor Intermittent Failure
    P0720 Countershaft Speed Sensor Circuit Malfunction
    P0720
    P0721
    Problem in Countershaft Speed Sensor Circuit
    P0722 Problem in Countershaft Speed Sensor Circuit (No Signal Input)
    P0723 Countershaft Speed Sensor Intermittent Failure
    P0725 Engine Speed Input Circuit Malfunction
    P0730 Problem in Shift Control System
    P0731 Problem in 1st Clutch and 1st Clutch Hydraulic CircuitP0732 Problem in 2nd Clutch and 2nd Clutch Hydraulic Circuit
    P0733 Problem in 3rd Clutch and 3rd Clutch Hydraulic Circuit
    P0734 Problem in 4th Clutch and 4th Clutch Hydraulic Clutch
    P0735 Problem in 5th Clutch and 5th Clutch Hydraulic Circuit
    P0740 Problem in Lock-up Control System
    P0741 Torque Converter Clutch Hydraulic Clutch Stuck OFF
    P0743 Problem in Torque Converter Clutch Solenoid Valve Circuit
    P0745 Problem in Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve A Circuit
    P0746 A/T Clutch Pressure Control Solenoid Valve A Stuck OFF
    P0747 A/T Clutch Pressure Control Solenoid Valve A Stuck ON
    P0748 Problem in A/T Clutch Pressure Control Solenoid Valve A Circuit
    P0750 Problem in Hydraulic Control System of Shift Solenoid Valve A Circuit
    P0751 Shift Solenoid Valve A Stuck OFF
    P0752 Shift Solenoid Valve A Stuck ON
    P0753 Problem in Shift Solenoid Valve A Circuit
    P0756 Shift Solenoid Valve B Stuck OFF
    P0757 Shift Solenoid Valve B Stuck ON
    P0758 Problem in Shift Solenoid Valve B Circuit
    P0761 Shift Solenoid Valve C Stuck OFF
    P0762 Shift Solenoid Valve C Stuck ON
    P0763 Problem in Shift Solenoid Valve C Circuit
    P0771 Shift Solenoid Valve E Stuck OFF
    P0773 Problem in Shift Solenoid Valve E Circuit
    P0775 Problem in the Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve B
    Circuit
    P0776 A/T Clutch Pressure Control Solenoid Valve B Stuck OFF
    P0777 A/T Clutch Pressure Control Solenoid Valve B Stuck ON
    P0778 Problem in A/T Clutch Pressure Control Solenoid Valve B Circuit
    P0780 Problem in Shift Control System
    P0795 Problem in Hydraulic Control System of A/T Clutch Pressure Control Solenoid Valve C Circuit
    P0796 A/T Clutch Pressure Control Solenoid Valve C Stuck OFF
    P0797 A/T Clutch Pressure Control Solenoid Valve C Stuck ON
    P0798 Problem in A/T Clutch Pressure Control Solenoid Valve C Ciruit
    P0812 Open in Transmission Range Switch ATP RVS Switch Circuit
    P0842 Short in 2nd Clutch Transmission Fluid Pressure Switch Clutch, or 2nd Clutch Transmission
    Fluid Pressure Switch (Clutch) Stuck ON
    P0843 Open in 2nd Clutch Transmission Fluid Pressure Switch Circuit, or 2nd Clutch Transmission
    Fluid Pressure Switch Stuck OFF
    P0845 Problem in 3rd Clutch Pressure Switch Circuit
    P0847 Short in 3rd Clutch Transmission Fluid Pressure Switch Circuit, or 3rd Clutch Transmission
    Fluid Pressure Switch Stuck ON
    P0848 Open in 3rd Clutch Transmission Fluid Pressure Switch Circuit, or 3rd Clutch Transmission
    P0872 Short in 4th Clutch Transmission Fluid Pressure Switch Circuit, or 4th Clutch Transmission
    Fluid Pressure Switch Stuck ONP0873 Open in 4th Clutch Transmission Fluid Pressure Switch Circuit, or 4th Clutch Transmission
    P0962 Problem in A/T Clutch Pressure Control Solenoid Valve A Circuit
    P0963 Problem in A/T Clutch Pressure Control Solenoid Valve A
    P0966 Problem in A/T Clutch Pressure Control Solenoid Valve B Circuit
    P0967 Problem in A/T Clutch Pressure Control Solenoid Valve B
    P0970 Problem in A/T Clutch Pressure Control Solenoid Valve C Circuit
    P0971 Problem in A/T Clutch Pressure Control Solenoid Valve C
    P0973 Short in Shift Solenoid Valve A Circuit
    P0974 Open in Shift Solenoid Valve A Circuit
    P0976 Short in Shift Solenoid Valve B Circuit
    P0977 Open in Shift Solenoid Valve B Circuit
    P0979 Short in Shift Solenoid Valve C Circuit
    P0980 Open in Shift Solenoid Valve C Circuit
    P0982 Short in Shift Solenoid Valve D Circuit
    P0983 Open in Shift Solenoid Valve D Circuit
    P0985 Short in Shift Solenoid Valve E Circuit
    P0986 Open in Shift Solenoid Valve E Circuit
    P1020 Valve Pause System Stuck Off
    P1021 Valve Pause System Stuck On
    P1025 Valve Pause System Sticking Off
    P1026 Valve Pause System Sticking On
    P1077 Intake Manifold Runner Control (IMRC) System Malfunction (Low rpm)
    /PCM)
