00 ex brake swap HELP
  • 00 ex brake swap HELP
    I have a 00 ex coupe, and I just got front and rear brake setup from a 99 GSR. I have the complete trailing arms, and front spindles. I am going to do the swap next weekend and throw some pics up.
    Do I have to change my proportioning valve? (if so which one should I use)
    Do I have to change my Master Cylinder ? (if so which one should I use)
    Will my brake lines just bolt up ?
    Can I use the GSR E-brake cables?
    I know you guys have done this before so help a brother out.
    Is it too early to bump this ?
      everything bolts up atleast it did on my EG dunno if an ek is diff u def ned a prop valve tho just get one out of an integra but make sure u get the one that matches ur car (abs or no abs) but everything should bolt right up
        my car is non abs, so which prop do i need? thanks
          yea just a like a 94 ls non abs valve its identical to the 1 u have in ur car jujst take out urs and put the lines into the new prop valve
            just for the record this is b18cya i'm on my buddy comp but if u need a hand let em know i'll help u out
              Thanks alot I appreciate the offer.
                your fronts are the same as a gsr also the rears bolt up no problem no need to change the fronts also do nt really need that prop valve but you can get it of of 94 and up integra with rear disk no abs you might as well get the booster and master if you want it legit as a full brake upgrade
