OK so my old calipers were bad and the piston was getting stuck so I got new ones and it seems like its happening again I wat can it be now I don't wanna keep getting new calipers all the time now the car has abs the light is on there is fluid the the box... so idk any help
caliper problems
have you messed with the master cylinder latley? i see this issues alot and most of the time it is the rod that hooks the pedle to the master under the dash is adjusted to tight ack the lock nut off spin the rod in and it usually covers it. good luck thoRIP Nick
