Is there a shop that understands offsets / fender rolling / wheel spacers / etc...? I need help with this and I'm interested in using Ichiba hub-centric wheel spacers so I'll have to have my OEM wheel studs cut down....
Cutting Wheel Studs / Flush Stance
You mean a recess in the back of the wheel?? Yeah it's not enough to fit the stud. I would have to use 25mm or bigger to NOT cut the studs and I don't think I need that much of an offset. I would rather use the Ichiba version 2 spacers that include pre-pressed studs right in the spacer itself. Taking out the original studs and replacing them with extended studs causes problems with the wheel bearings from what I've been reading.
Originally posted by EHBoostedSi View PostYou mean a recess in the back of the wheel?? Yeah it's not enough to fit the stud. I would have to use 25mm or bigger to NOT cut the studs and I don't think I need that much of an offset. I would rather use the Ichiba version 2 spacers that include pre-pressed studs right in the spacer itself. Taking out the original studs and replacing them with extended studs causes problems with the wheel bearings from what I've been reading.JimmiSPEC
If you need your fenders rolled PM me!
