need help asap k20
  • need help asap k20
    I need some one that knows a lot about k motor from bridgeport like today my car is acting up and I want it ready for honda day .... Contact 203--543-9544
    Whats it doing
    Follow Me On Instagram
    Jdmkid618
      Ok car don't wanna turn on and when it does it runs really lean like if I punch the gas is puts and then shuts off
        what kinda car is it? and when did this happen? like what were u doing?
          check engine light on? scan and report back.. off hand my $ is on a crazy vacuum leak or map sensor problem maybe..
          BACK FROM THE DEAD
          FUNCTION > FORM
            Its a 2002 honda civic si I was drivng home ffrom ny and about an it was great. For the first hour then after that we hit trafic and the car shut off then when I turn it on it started doing it.
            And yes it say low curcit mapsensor but I'm on a budgit so I don't wanna by it and that's not it
              -_-
                how do you know thats not it?
                BACK FROM THE DEAD
                FUNCTION > FORM
                  look for a vacuum leak if youre sure its not the sensor.
                  BACK FROM THE DEAD
                  FUNCTION > FORM
                    Cuz it had mad codes such ass p1298 p0171 p1164 p1163 p0107
                      p1298 is a eld (electric load detector) code. a bad eld could be causung your problem.
                      BACK FROM THE DEAD
                      FUNCTION > FORM
                        Ima buy the map and the eld now will see what happends if not I'm riping the motor out
                          What's that gonna accomplish. Lol
                            And get a new one
                              It doesn't sound mechanical or sounds electrical. If that's the case a new motor will do absolutely nothing for you.
