2003 Honda CRV Problem " no start" HELP!!!!!
  • 2003 Honda CRV Problem " no start" HELP!!!!!
    ok guys I bought an 2003 Honda CRV has a K24.....off a lady for CHEAP!! She said that she was driving 25 MPH in her neighborhood and the CRV just died, she had it towed to a shop down the road. The mechanic told her the timing chain snapped and she needs a new motor. $3000."bull!!!" ..... I buy it and tow it home... the car turns over and i see the valve train moving fine, i check the fuel pressure and its good. ran compression 130psi across the board....I check spark and in all the cylinders its sparking an orange color not a bright blue or white.... I was thinking a weak Crankshaft position sensor single. or the coils but... I cant see all the coil packs would just start dieing and kill the car all at the same time...... I also tried started fluid and it wont even spuder.... where should i start... I just ordered a CKP...
    BUYING LOW SELLING HIGH
    I also checked the fuel injector and there all pulsing, And I changed the spark plugs to new ones...
      You should start by selling it to me!!
        LOL!!!!! Got it for 700 Bucks!!! trying to be into it for a grand... I have another dealer friend that ships these and will give me $4700.
          how much you want? =)
            Im gonna get it running i hope and clean her up and post on craigslist... if i dont get any bites ill sell it to my shippers
              give you a grand right now =)
                I got $1500 on it right now
                  I bet u do...
                    lol i sold mine for a good number and also got it cheap mine felt weak and i did a valve ajustment and gained my compression back 100%.. if u have weak spark check all electrical parts battery good, alternator good , coil packs good, spark plugs good . did u actually check the chain ? make sure its dead on .
                    D and G auto member #5
                      I didnt pull the cover.. I just figured that my compression is mint that the chain cant be off a tooth... battery is weak, Jumped off of my tow truck so i figured it was good... Ill check everything again
                        Perfect motor for boost!
                        Boosted K all day
                          SO STUMPED RIGHT NOW!! We checked everything!! Timing is Dead on, Injectors are working getting good fuel pressure, Changed all coil packs, and we are getting good spark....Changed crank sensor, Compression is 170psi Across the board, Disconnected exhaust just to rule out clogged cat..... We cant even get it to Spudder like it wants to start.. I used starting fluid and NOTHING!!! I HAVE NO IDEA
                            Also put brand new battery and plugs in..... I just dont get it!!! no stored codes cuz battery was dead. WE HAVE EVERYTHING TO MAKE THE CRV START BUT NOTHING!!!
                              Sold it $4000 not running!!!
