Seeing if the more experienced on here will know or figure out what im talkingm about,
1997 civic ex with a h22a h2b swap. Chip and tuned p28,
Was running fine yesterday until i noticed it simply turned off on me, i put it in nuetral and tried to started it, didnt start, when i coasted into the parking lot i tried to start it, but when you put the ignition on to prime the fuel pump, i only heard the fuel pump relay click, no fuel pump, and the CEL didnt click off, i checked the thermostat ground, tranny ground, fuelpump fuse, swapped the fuel pump relay, even swapped the computer to try it, and nothing. We took the fuel pump and put direct power and ground on it and it turned on, so we rigged a switch to manually turn it on, we primed it and went to start it but just cranking no start. Anyone have this problem before its kicking my ass.
Any feedback will be great, thanks
