f22 clutch help ?
  • f22 clutch help ?
    so my clutch keeps getting air in it and i changed just about everything master cylender twice resivor bradded hose line from tranny to main line slave i cant find enymore leaks i have a 93 honda accord f22
    i also can pump the clutch up and it works when it warm but when i let it sit and its cold i have to keep pumping it up till it worok i bleed it 100 times and still nothing
      is your slave cylinder leaking?
        check that tha fitting on tha lines from tha slave to tha master are tight also make sure tha fitting from tha resivor and tha top of tha master is tight also they somthimes come loose brand new
          takes a longass time to bleed...bleed the shit outta it
          BACK FROM THE DEAD
          FUNCTION > FORM
            look at cms from the inside of the car sse if its leaking. maybe u forgot to tighten all the fittings
              everythings tight i had the dealer bleed it and cheak everything i changed the clutch and everythuing new tranny and its good but i need to know what mount to use for a 97 accord tranny ina 93 accord the 97 mount doseint look like it fits and the 93 one deff doseint fit i have it in with one bolt
                Bleed it good bro
                CHUPACABRA RACING!!!!!!!! FTW PAPA
