h22 starting issues
  • h22 starting issues
    has fuel have spark but wont frigon start...timings good..have grounds ....i give up...
    !!ACCORD POWER!!
    vouchez- my momma
    compression check and leak down test
      check every thing again.engine timing,ignition timing and firing order.if all this checks out check ure compression
      CGP CL9
      1993 EH3
        maybe bad wires??....check all the wires to your ecu, try pushing or wiggling them slightly as someone starts the car....if not then the only thing i can think of is compression also...good luck
