I have an h22 in ek hatch for 2yrs now...I recently bent valves and took head off and had machineshop replace them...haven't had much time so its been parked for entire summer, till now that I put it all back together..
Problem is : it has spark, fuel, but it won't turn over...when I try to start the only thing that happens is that everything turns, timing belt , cams etc.....but no crank...just the noise from all the belts and pulleys turning like if it was off timing..which I did and checked over and over and is fine..... I also checked fuses and grounds on valve cover(2 of them) frame to trany, harness to thermostat housing....everything ok...I even swaped dizzy from a running h22 and nothing...and spark plug wires on dizzy top two 1,2 then lower 4,3 from left to right......I am, using the same plugs I took off 2months ago, but it should still try to start right? . Help please
