what going on guys, i am going to buy my sisters integra off of her but it needs the rack and pinion replaced, does anyone know of a good write up that explains step by step on removing and replacing the rack and pinion? it is an automatic 94 integra with a 99 swap in it. any info is greatly appreciated.
rack and pinion replacement help
its pretty easy just undo your tie rod ends, then take of the steering linkage. its like one 10 or 12mm under the dash you can see it and its easy to get to. then take out the bolts that hold the rack into the car. should be like 17 or 18mm on the driver side and like 15 or 16mm on the pass side. after you get all those out you have to move it around alot but it should come out. hope this helps a little.
Originally posted by 00civicLS View Postits pretty easy just undo your tie rod ends, then take of the steering linkage. its like one 10 or 12mm under the dash you can see it and its easy to get to. then take out the bolts that hold the rack into the car. should be like 17 or 18mm on the driver side and like 15 or 16mm on the pass side. after you get all those out you have to move it around alot but it should come out. hope this helps a little.Originally posted by Mr Layy View Post^^^^^thank you I was trying to find him write up, but you answered the question!Morning Wood Is Such A Waste
**Rest In Peace Nick Haines**
