GSR swap for ek sedan
  • GSR swap for ek sedan
    Looking to swap my ek sedan with a gsr. Besides the motor what else do I need? Is there a place where I can get the swap put in professionally ? I don't have much space to play with.
    93 civic sedan EX-project
    Most places will charge a lot to swap the engine. If you can do it yourself you don't need much space at all. You will need mounts harness ecu axles rear t bracket. If you need an engine I have a complete gsr swap for sale
      if you have the money for the parts I have a shop for you. It would be swapped and running in 3 hours if you have everything and I mean everything don't forget any parts lol.....
        You would need 2000 civic si post mount bracket and the rear t bracket contact 4133283924 for more info and pricing on swap
        Follow me @bolacan413
        Follow the build @k_insight
          Most sites I been looking at include axles shift linkage and I believe harnest but not mounts. But I been reading most of these " gsr " are the motors dose that make a difference in anything ?
            How much would that cost me? And by everything what parts exactly will I need???
              You'll need the following in parts...
              99/00 civic si post Mount.
              99/00 civic si rear T bracket
              If the car is a dx or lx, you'll need rewiring to make it work.
              And then the swap n ecu...
              ~StayinFRESHSINCE1982~
              SPUNKY MONKEY CREW MEMBER #1
              203 CREW MEMBER #33
                I got the mounts if you need em
                  The harness included will most likely be cut and if it isn't it still won't work because it'll be set up for rhd
