k20 block k24 head??
  • k20 block k24 head??
    Got a z1 block mint witha k24 head wondering if anyone had ideas on this bulid n wat to do to make it run
    Work hard Play hard S.I.C all day
    Wat kind of k24 head.... If its anything other than a k24a2 head its pointless.... Just get a k20a2 head ... Do the job once and you will be happy
      I say slap it together and just boost it sounds like something fun
        Ya its a k24 a2 off the tsx i thinkin itb over boost for now never seen a k out here with that setup yet
          There's probably a reason for it
            Ya that itb are madd expensive n i wanna see if it makes good power you know but well see when its all put together
              theres a reason why you havent seen this setup yet, the k24 head doesnt have the good flow that a k20 does, plus i believe the k24 heads cross over is like a single cam vtec only hits on intake side. but i could be wrong
                That's 04-05, 06-08 are both sides i think. ^^
                  K24 block
                  K20 head
                  Ftw
                  Enough said
                  Do it right the first time or stay b series
                  Follow Me On Instagram
                  Jdmkid618
                    Mad people in here spreading misinformation. Take from someone who has a k series - nothing wrong with an 24a2 head on a 2 liter block. It's practically the same as the 2 liter Ivtec heads. The 06 and up have the most aggressive oem intake cams and 1mm oversize intake valves. Just meed swap a 50 degree vtc gear on it. Go to k20a.org and read there, these guys would have you trying to put a y7 on there.
                    WTF?! Racing.
                    ________________________________
                    Blowing Smoldering Holes in Honda Motors Since 2005... ish.
                      K24a2 has vtec on both cam lobes . K24a1 on one cam lobe. I'm interested to see the out come of this. Usually its a k24 block and k20 head.
                      Boosted K all day
                        Wanna c how it goez too
                          Are if you wanna buy a k20a2 head with type s cams
                            I got one*
