b16 block with gsr head wat do u think
  • b16 block with gsr head wat do u think
    wat u think of this combo wat shud i do to it wana stay all motor asa dd b dependable with sum pep possibly goin in a da
    Integranation founder
    its jst like having a regular b16. b16 are short strokes. so gsr head wont do nothing.
    just go lsvtec or gsr bro.
      my boy has this same setup and its a beastt gsr head would raise ur compression ratio
      TURBO 2001 IS300
        cuz he sprays the shit out of it lol
          not even he does run without the bottle
          TURBO 2001 IS300
            gsr will raise the CR
            but for one leo is right you can only get so much from a 1.6 bottom end. do lsv with itr pistons or smething
              i know someone with this setup, runs good if that whats in your budget because lsvtec conversion cost as much as a B16 block or close to it
              Money Ain't a Thing! Crew Member #9
                We got a eg coupe over here that has that set up it runs like shyt though but it depends on how u build it though
                  lsvtec isnt really a good setup actually most people say its not recomended its a waste cuz i was gonna do lsv but then with some research done found out it aint worth it
                  integranation member #8
                    lsv done right will run right and reliable theres many things said about lsv you cant just read something off a forum and expect that to be an answer thats another person juss like me and you stateing there own opinion on the subject...
                    TURBO 2001 IS300
                      well yea if you have the right budget then yea you can build yourself a pretty good running lsv motor
                        ls/v's only has three weaknesses 1. bi-metal stock bearings,(ls has the weakest bearings honda ever made). 2. 8200+ redlines.. stocks rods don't like that shit. 3. factory rod bolts.. besides that there ain't no real problem. stock rods are good for the job anyways.
                          x2 i know of quite a few ls/v's that r reliable and run very well... its all how u build it
                            gsr block b16head. thats the way to go but my boy had a eg with a b16 block and a gsr head it moved decent
                            USMC
                              to be honest gsr/b16 block is not a good set up....1.6!!! not much to rave about there. and still to this day lsvtec set ups are or can be a powerful and fun set up when done right. people cheap out on them or dont know what they are doing that causes shit to blow. but ANY motor/set up is only as reliable as the builder and the parts going into the build. I dont care if its H, single, B...any set up!
                              My boy in PA has a 226whp 1.8 lsvtec running LOW 13's...he daily drives it, AND it consistently see's 9200 RPM'S!!!!
                              Team T&W
                              Winning is the only option
