good low compression single cam motor/head
  • good low compression single cam motor/head
    What would be a good low compression motor for a single cam and or low compression single cam head?
    D15b
    Always on that fire
      Vitara pistons
      Follow me @bolacan413
      Follow the build @k_insight
        Just get a z6 n low comp pistons
          Word ok been thinking of getting a new motor staying with the single cam but what about a y8 and get low comp pistons or just a waste? I still like having that small little bit of vtec
            Or anyone know anything about the dual stage vtec shit? Been looking at that but idk to much on it and I've looked it up but I couldn't find anything so I think people just don't use that dual stage vtec single cam at all
              Originally posted by jealous1shateric View Post
              Vitara pistons
              That's fine. If u get a y8 order yourself a z6 crankshaft and a set of bearings to match and some arp hardware. I have new arp rod bolts I'll sell u for cheap.
                Stay away from it
                  Originally posted by H22SteakSauce View Post
                  Stay away from it
                  ok easy enough lmfao whats so bad about it?
                    You could run a y8 head but I wouldn't use the bottom end they have oiling issues and spin bearings at high rpms more often then not. The dual stage vtec is a system made only for better gas mileage. It basically runs your engine on 2 valves per cylinder at low rpms, then switches to 4 valves per cylinder in the mid range, and finally switches to an aggressive cam at high rpms like any vtec system. To make it work correctly you need to get the JDM ecu made for that engine which is hard to find and runs like $900 last time I checked. Not really worth it in my opinion
                      They just need a z6 crank. The crank is the weak point. And yea what he said about the vtec e
