headlight issue
  • headlight issue
    not sure where to put this but i got a single cam so i figured here soooo ....the problem is i have a headlight out the bulb is good the fuses are good but i took a test light and i am not getting any power to the headlight or to the new fuses under the hood ....again all tested with a matco test light ...the radio fuse light right up when tested and the other side of head light ..im stuck and sick of gettting pulled over for a bad light
    N.F.G crew member #2
    might sound stupid and simple but swap the bulbs out and see what happens. i had a turn signal out and replaced it and it was still bad, started poking around and trying to diagnose shit, turned out the bulb was bad out the box. might not be your situation but its easy enough to at least give it a try
      Like said above. All so check the wires for brakes.
      R.I.P NHSWAPS13203
        ight ill give it a shot thanks
