I'm leaking antifreeze out of my a/c drain line can someone help me out with this. Thanks ctv
need help please
sounds like a bad heater core......tucked harnesshttp://ctvtec.com/showthread.php?t=51421
R.I.P NHSWAPS13203
No.
That drain line is an internal line that connects only on the heater core. Check your passenger side carpet and see if it is wet.
The only way coolant should be able to come out of that drain is if the heater core cracked or is defective.RIP NHSWAPS13203
is it antifreeze or is it a/c refrigerant with dye in it? it might be your a/c evaporator instead of your heater core leaking. take a blacklight and see if the shit thats leaking out glows. if so its refrigerant and not coolant..BACK FROM THE DEAD
FUNCTION > FORM
