code 3 issue
  • #16
    Ok it's just backwards from what Im looking at it
    Follow me @bolacan413
    Follow the build @k_insight
    • #17
      I'll try tomm thanks
      • #18
        any pic with map . Sensor pin out?
        • #19
          Im try to hunt a good sensor I did as pin point test said sensor was bad
          • #20
            [IMG] Uploaded with ImageShack.us[/IMG]
            R.I.P NHSWAPS13203
            • #21
              Thanks Bro I'll try it tomm... I had as master cylinder leak into intake manifold so that could of been messing around with the vaccum I'll keep u updated I saw d21 on some other sites
              • #22
                You can use d21 with no problem cause d21 and d22 do the same thing. One of them just has other things on it.
                R.I.P NHSWAPS13203
                • #23
                  Ok thanks
                  • #24
                    who has a harness they can go look at right quik and get the colors in the right order...?
                    • #25
                      2point1 knows his shit trust me
                      • #26
                        not sayin he dont.... but somethin is obv wrong
                        • #27
                          two obd1 stock harnesses with different wire colors.....
                          R.I.P NHSWAPS13203
                          • #28
                            its clear yellow an green go next to each other.
                            • #29
                              yellow=d19 green=d21 or d22 and the last one goes to d17....this info is for obd-1 ecu.....
                              R.I.P NHSWAPS13203
                              • #30
                                try a new map?
