I have a Map sensor issue
someone changed the car harness to obd1 with out map sensor on fire wall.
I tried wiring it straight to. The ecu usin pins d17, d19, d21
and no luck at all code is still there
any helpwould be appriciated
car is a civicdx
D17 left wire color white
d19 middle green wire
d21 right yel/grn
I swapped D17 and d19 around...
didn't work.
D19 and d21 were swapped still have check engine light on..
Now does the map share the ground with another sensor?
car is a civicdx
d21 right yel/grn
didn't work.
