crank sensor
  • crank sensor
    im new to the honda game so this may sound stupid but does a d16z6 from a 92-95 civic have a crank sensor if so where is it located i have a crx si wit the d16z6 swap in it and im stumped cuz i did a head job on it n it wont start new main realy, dizzy, fuel pump n strainer, new plugs wires , fuel fiter , timing belt water pump tensioner i really dont know but every time i crank it ir will start and die so i wanna say crank sensor ant input plz post thank you
    Google is your friend
    Follow Me On Instagram
    Jdmkid618
      Check timing and valve lash. If your trying to use an obd-0 ecu with an obd-1 dizzy it work work. Do you have any codes?
      R.I.P NHSWAPS13203
        crank sensor is inside the dizzy
          check your thermostat ground it might be loose or you may need to sand it a lil for a better connection
