Please help V-tec issue
  • Please help V-tec issue
    I just swapped over a new single into my coupe.When i hit vtec the car sputters and stop accelerating. it happens at 5800 rpm. Is this a bad vtec solenoid or a bad crank sensor.
    HWR
    13203 RIP Nhswaps
    School of Hard Knocks
    is vtec wired up? any cel?
    R.I.P NHSWAPS13203
      is the light on?
        the vtec is wired up. and i have a cel from the knock sensor which i replace today so im driving it till it goes out.
        HWR
        13203 RIP Nhswaps
          Wut swap y8 ?
          860 member #18
          puerto roc #1
          Cosa nostra
          ASAPRadio.net
            yup it a y8 swap
            HWR
            13203 RIP Nhswaps
              Bump help this guy
                Wat ecu u got?
                I hate thieves wit a pasion, stop being some bums and get a job....
                  Hmm maybe the solenoid not sure though. If it ends up being that and you need one PM me I have one from a y8.
                    p2p ecu.
                    - i will pm if it the solenoid
                    HWR
                    13203 RIP Nhswaps
                      thats is exactly what happened to me i changed everything vtec solenoid to gaskets and come to find out it was the ecu try using another one
                      knuckk.
                        Just switch gears earlier haha jk, but please change your located that shit is annoying
                          Bump any help on dis.
                          HWR
                          13203 RIP Nhswaps
                            The vtec pressure clip from the harness , prolly has a short , check it out cause my coupe used to do that around 5200 , figurin out the wire came out from the pressure clip
                            98Ex DD EJ8 ROADRUNNER
