d16z6 new parts in side engine now crank wont turn need help
  • d16z6 new parts in side engine now crank wont turn need help
    hey i got a d16z6 engine i put new bearings new piston rings and now the crank wont turn need help please i did every thing right but dont feel like taking it apart agian
    crank wont spin
    More info on exactly went down and how it was reassembled and with what parts
    860 member #18
    puerto roc #1
    Cosa nostra
    ASAPRadio.net
      Overtorque main studs??
      Overtorque rod bolts??
      If that's the case go buy some new main and rod bearings cuz I won't use them again
      S3-R
      Stage3-Racing
        i bought new stock parts king bearings nrp piston rings and the lube stuff at advance and put everything together in the block torqued it to spec and now it wont spin when i try to spin the crankwith a braker bar
          its torqued to spec
            Ok are the clearance within specs? Just saying u can't just throw an engine toghetor without checking all the specs. Did you plastigauge?
            Not judging ur mechanical skills I'm just about maybe 98% certain that's y you can't turn it over easily checks all your specs then rebuilt.
            Edit: is the head on. if it is try removing the sparkplugs it might make it easier.
            Edit:More things to consider
            P2V clearance if the head is on
            Glwyb
            S3-R
            Stage3-Racing
              yes did all that man
                you cant just assemble an engine without a machine shop checking clearances ect ect...
                  X2 talk to single slam is the d series guru.
                  But I think the specs might be off still. Trust re check it or send it to a shop since you don't want to do it.
                  S3-R
                  Stage3-Racing
                    It kills me that he just posted this in the for sale section and failed to mention that the engine doesn't spin untill another member mentioned it.
                    860 member #18
                    puerto roc #1
                    Cosa nostra
                    ASAPRadio.net
                      thats why i said shoot me an offer i didnt put a price down because of that
                        wrong bearing sizes, u r way off with the specs.
                          wrong
                            that's why i love oem colored bearings. you can't go wrong with those bearings.
