Help???
  • Help???
    Alright so I was driving my car when all of a sudden my radio kept shutting off I got home turned the car off tried to start it again and nothing.everytime I turn the key to the on position theres a clicking noise coming from the main relay.then when I turn it to try and start it the noise stops and nothing happens.what could be the problem my main relay?I have a 98 civic ex stock single.any info will help.
    Originally posted by LS/Vtec
    sounds more like a alternator
      altenater
        x2
          Make sure the batterys not dead. If it is then your alternater isnt doing its job, or the positive connector on the battery/alternater is dirty and draining through your ground/not charging.
            clean ur terminals, check for loose grounds.. then check for dead battery, and alternator. Its somewhere along those lines
