does anyone know the order of the fuel injector clips by color
injector wire help
yeah i went out after i posted this and checked the rotor to see where it was pointing when motor was tdc and found it was pointing to #4 so i just pulled the dizzy off and changed it to #1 put it back together and fired right off. i hate when i rush the last like three steps to get something done and overlook something stupid like this. but anyway thanks for the responces.
ok one more question i just got around to finishing up my swap i hooked up my vtec and that took care of the check engine light. Now the only thing is that under like 3800 rpm my car wont run for shit and is back firing every once in a while but once i hit like 3800 it smoothes out and runs fine
Did you check and see if your tps and iac valvee wires arent on the wrong way they look the same go out and try it deff worth a shot bro maybe it's that just throwing it out there but it cleaning up after 38 leads me to think you mite have another small issue just try it and see.860 member #18
puerto roc #1
Cosa nostra
ASAPRadio.net
"Hatred is the coward's revenge for being intimidated.â€
