need help on how to install install ls in ek with obd 2 vtec harness from 96 ex
harness wire
What year is the motor?
What ecu are you using?
For the most part the harness will plug into all most every thing. Depending on what distributor,injectors and alt your using,that might not plug in.tucked harnesshttp://ctvtec.com/showthread.php?t=51421
R.I.P NHSWAPS13203
Your alt,injectors and distributor need to be swapped for obd2 or the plugs converted.tucked harnesshttp://ctvtec.com/showthread.php?t=51421
R.I.P NHSWAPS13203
