ls in ek trouble
  • ls in ek trouble
    I recently spun a bearing on my b16a so swapped in an ls obd2a into my ek which im running a hondata s300 in a p28 with vtec disabled...problem is when I took out the ecu to run a stock one I used a obd1 p75 car starts but bogs out when I try to drive it...anyone know what it could be? Was told to run a obd2a p75 ecu...thanks for any help
    My vtec goes BWAAAAAAHHHHHHHHHH
    Check ur engine codes
    Follow me @bolacan413
    Follow the build @k_insight
      Ls came with aftermarket fuel rail and stock injectors also would that have anything to do eith it....havent checked my engine codes yet will check em today tho gudluks bro
        Prolly map sensor
          iacv valve runs on different ecu
          pinouts
            Crank sensor hooked up?
              Yes crank sensor is hooked up...wirh the s300 runs fine and healthy but acts up when I put on the p75 and I need the s300 for my b16 swap so im tryna figure it out....thanks to the ppl who have replied appreciate the help
