Gsr help
  • Gsr help
    CT I need some help! My gsr won't start it cranks over but doesn't actually start I get power to the fuel pump, I have spark,
    the distributor
    fuel pump/sending unit
    the plugs and wires
    fuel filter
    main relay are all brand new parts
    For some reason it still won't start any ideas!?
    Are you getting power to the injectors? Yellow/black wires.
    R.I.P NHSWAPS13203
      What he said ^. Also check to make sure it's on timing. And firing order.
        I didn't check the power to the injectors yet thanks and I know it's in timing and firing order is good, on one of the hottest days last month I turned my car on and let it idle for a few seconds and it just shut off on me.
          you should still check it bro if it jumped a couple teeth it will just crank for days
            Word definitely man Ima check that tmo thanks for the help
              I've come accross brand new distributor. Defective out the box. Check it gain
