radiator fan smh!!
  • radiator fan smh!!
    my fan womt work wen i splice the two wores the relay just clicks ttied aNother relay same ish... what is my problem please.. i also tried miltiple fans
    With the fan switch plug jumped are you getting 12 volts to the black/red wire at the fan plug?
    Make sure your getting ground at the fan plug.
    Does the fan work if you hook it up to the battery?
    Could be a brake on the wire some where.
    R.I.P NHSWAPS13203
