Help!!
  • Help!!
    Ok so I got my coupe it's got a Ls the kid I got it from is a mechanic but when I got it he said it needed a clutch an he had one an put it in for my I was driving it to break it in an it started slipping... So I was like ok I called my boy he helped put the clutch in cuz his cousin sold it to me told me it was the slave cylinder so I had one put in an now the clutch still slips am even more when the car has been drivin for a bit is it the clutch or tranny or could he have done something to it to make it that way?
    Always on that fire
    Always on that fire
      Tranny Fluid? did u putsoem in after ? Not sure if its causes the same afect like an auto but u do need to change/ add to ur manual tranny. also is the clutch for cable or hydro?
      Text:8604810204
        Sounds to me like he re-used the old pressure plate and the clutch isn't being pressed against the flywheel hard enough to keep it from slipping. Either that or he got the clutch dirty as fuck putting it in
          ^ if you replaced master and slave cylinder then check the pressure plate and fly wheel and check if there something on the clutch pad
