wats better to boost b18b1 or b20z2.????
  • wats better to boost b18b1 or b20z2.????
    have 2 motors to swap in my del sol (b18b1)and(b20z2) but cant decide witch one would be better to use since im thinking about boosting ,,any suggestions ???
    build the b20 for a b20vtec monster
    eh9 jdm b16
    Pimpbays
        x2
        J.R. Built not Bought
          Stock I say ls,but if ur gonna build 1 it doesn't matter cuz they use the same crank/rods just different bore (witch I assume would be redone as well)
            B18 boost. B20 all motor
              Id say ls but id go with a b18 a1 some reason ppl n ct dont notice that the a1 has better torque n like 4less hp but is better for a all motor build/ turbo if u do a lsv
              Work hard Play hard S.I.C all day
                b18
                  b20 is better for all motor
                    do a j35 :O
                    but naw I love the b20's.
                      Just use a b18 block and b20 head lol then u will have both
                        B20!
                          B18 for boost defenetly ..
                            lol really the b20 would be better for boost it make more toqure and in turn makes more power lol the motors are the same one is a bigger bore and lower compression the b20 with the lower compression will be much more happy under boost
                            b20b3= 9.0-1
                            b18B = 9.2.1-1
                              B18 sleeves
                              B20 sleeves
